Dummy/fake alarm LED - ZX6R Forum
  • 2 Post By tsunx4
  • 1 Post By RJ2112
post #1 of 6 Old 08-28-2019, 01:06 PM Thread Starter
Soody's Avatar
I Ride: ZX-6R B1H
Has anyone down this? I did a search but couldnt find anything. Ideally want to do it so when the bike is off the LED flashes a
And when it's on it goes off. Without using a switch.
Bounce Bounce
Soody is offline
post #2 of 6 Old 08-29-2019, 02:00 AM
tsunx4's Avatar
I Ride: 2014 ZX-6R & 2000 Suzuki GSF600S K2 Bandit
I'm quite curious why you need this?
I mean, if you're good with soldering iron and have basic understanding in electronic components this can be done for couple of bucks/pounds. Something like LED driver circuit sensing current from ignition on / acc line.
But why not just install real alarm? You're from UK, bike theft over here is on it's peak at the moment. Even cheap generic ebay alarms are loud enough to deter some opportunistic yobs on mopeds from rolling your bike from drive / car park.
RJ2112 and Gawernator like this.
tsunx4 is offline
post #3 of 6 Old 08-29-2019, 10:25 AM Thread Starter
Soody's Avatar
I Ride: ZX-6R B1H
I had an alarm on the bike and it had to be taken off as it "spiked". The LED was left on so want to turn this in to a dummy LED. Bike has an immobiliser, amoung other noisey security measures. The way I look at it is if someone sees an LED not flashing they would straight away think "no alarm" where as they may think twice if they see it flashing. I get your point though.
Bounce Bounce
Soody is offline
post #4 of 6 Old 08-29-2019, 12:16 PM
You would be better off having the LED powered from a disposable battery, than connected to the bike battery. Parasitic power consumption has discharged many a battery.
post #5 of 6 Old 08-29-2019, 12:50 PM
Gawernator's Avatar
I don't see the point
http://www.gawerracing.com
Gawernator is offline
post #6 of 6 Old 09-09-2019, 04:22 AM
KevAmiga's Avatar
I fitted an alarm / immobiliser / tracker to my ninja this week, was simple enough to fit (and that was it being fitted correctly, not thrown in) and it comes with an LED, plus it alerts the key fob if the bike is moved, as long as its within range (500 meters i believe it claims).
99 ZX6R / 2016 Montessa Cota
KevAmiga is offline
