2006 zX-6r Wiring harness - ZX6R Forum
post #1 of 17 Old 08-27-2019, 07:44 AM Thread Starter
So I picked up a 2006 ZX-6r for cheap and ordered a (new to me) wiring harness for it because the old one was spliced to hell. Well I got it all buttoned up last night and went to start it but it wouldnít turn over. Turns out I missed a plug and canít figure out where it goes. its pretty much right under the seat about even with the battery but on the opposite side. Here is a a few pictures of it, any ideas?
clarkad1234 is offline
post #2 of 17 Old 08-27-2019, 08:46 AM
Thats not a plug. Its actually a test port the manufacturer can hook up their computer to. It just stays like that. Thats what people use for the "jumper mod" for some more power.
Scorpi0 is online now
post #3 of 17 Old 08-27-2019, 08:52 AM Thread Starter
I finally figured that out. I had it turning over before I switched harnesses but I had to basically hot wire it because I was missing an ignition at the time too. So now Iíve got a new ignition and wiring harness but canít get it to turn over. The key will turn on and give power to the cluster but nothing when I hit the start button.
post #4 of 17 Old 08-27-2019, 08:54 AM
Neutral light is on?
post #5 of 17 Old 08-27-2019, 08:58 AM Thread Starter
Thereís also a red wire leg that comes off of my harness right before the 30A main fuse hookup if youíre coming from the rear. Any idea about this??
post #6 of 17 Old 08-27-2019, 09:00 AM Thread Starter
Yes neutral light comes on. it also flashes a yellow light and says fuel which is understandable because I know my fuel pump isnít priming, but before I could still get it to turn over whether fuel was present or not.
post #7 of 17 Old 08-27-2019, 09:02 AM
Not sure what that wire is but it doesnt look original. Maybe someone else on here might be able to figure it out
Is your ignition fuse good?
post #8 of 17 Old 08-27-2019, 09:08 AM Thread Starter
Yes 10A ignition fuse is good and every other fuse Iíve found so far is good
post #9 of 17 Old 08-27-2019, 09:12 AM
Are those 2 black and yellow wires connected to that red wire u found?
post #10 of 17 Old 08-27-2019, 09:32 AM Thread Starter
Yes they run from the harness into that little plastic rectangular terminal and then the red wire branches out on its own
post #11 of 17 Old 08-27-2019, 09:36 AM Thread Starter
Update: okay so Iíve got it turning over now (went back and took the whole harness out again and hooked it back up once more retracing my steps) but still no start. Anyone got a troubleshooting process for Fuel delivery?
post #12 of 17 Old 08-27-2019, 09:37 AM
Never mind...looks like u got it.
post #13 of 17 Old 08-27-2019, 09:41 AM
Hereís a question: how do you know the new (and cheap) wiring harness is good? It looks like it has had at least one modification with that red wire...
riverszzr likes this.
Duc995 is online now
post #14 of 17 Old 08-27-2019, 09:42 AM
Is the tip sensor plugged in? Is it installed in the upright position?
post #15 of 17 Old 08-27-2019, 09:44 AM
and, earlier you had stated you had no fuel pump prime.......is that sorted out now?
kill button is not in kill?
ignition switch is a known good switch and all wires on the back are soldered and secured?
When it is cranking over..........
do you have spark and fuel?
sixer likes this.
