05 plate non start code 35 stored - ZX6R Forum
post #1 of 3 Old 08-24-2019, 07:42 AM Thread Starter
Hi peeps, I have a 05 636 won’t start turns over but no priming from the pump, code 35 stored for immobiliser amplifier which I’ve changed still won’t fire, before it died completely it cut out on me a few times mid corner then took a while to fire, ive had a quick look at the tip over sensor and you can feel the weight moving about, ive heard about this fault but never seen a completed thread or how it was rectified, bikes been sitting all summer now and really don’t know what do try next any help welcome
Cheers
Lee Berry is offline
post #2 of 3 Old 08-24-2019, 08:18 AM
Start taking apart every electrical connection you can, and remove any corrosion you find there. Treat each point you disassemble with a doping of dielectric grease to prevent future corrosion. Make sure you do the same thing for the ground/chassis connections as well.
post #3 of 3 Old 08-24-2019, 10:19 AM
Phill636's Avatar
I Ride: 2005 zx6r 636
That code covers various parts in the imobilizer circuitry including the key malfunction. The chip inside the key. If you have the master key try that before changing other parts.
Phill636 is offline
