2019 zx6r slipper clutch - ZX6R Forum
 10Likes
post #1 of 16 Old 08-23-2019, 07:53 AM Thread Starter
davebibbs's Avatar
Hi all. First post
Iíve recently bought a brand new 2019 zx6r KRT. As far as I can tell from research, it has a slipper clutch.
Now Iíve never ridden a bike with a slipper clutch before, however I have owned several Super and Suoersport bikes in the past (this is my first return to bikes in over ten years) and was semi competent at blipping and downshifting so no major drama.
Problem is, so far as I can tell, it doesnít seem to be very ďslippyĒ. To be honest it feels exactly the same as my last bike that didnít have one (2005 CBR600RR).
Two part question:
1) Can someone confirm it does actually have one and I havenít made a mistake?
2) Does it only work in a particular rev range? Iím still running in for context and so not caining it. Anyone have one too and can comment.
Thanks.
David.
davebibbs is offline
post #2 of 16 Old 08-23-2019, 08:16 AM
Originally Posted by davebibbs View Post
Hi all. First post
Two part question:
Thanks.
David.
Yes, it has a slipper clutch. Works well at the track and I haven't had the rear lock up on me. I would imagine that it doesn't do much in the lower RPM range.
JL99
post #3 of 16 Old 08-23-2019, 10:32 PM
1) yes
2) the function is related to load, rather than RPM directly:
Back torque is greatest in the lowest gears, same as 'forward '. Chop the throttle at high speed in second, drop a gear and pop the clutch without revving the motor and the engine compression will refuse the change in shaft speed much more than in higher gears. Skidding, squirming, wheel hop can occur.
The slipper function is initiated by that force, and consists of a simple set of ball bearings in ramped grooves. The rear wheel 'backwards' load twists the plate one side of the groove is cut into. That twist is translated into a jacking motion, that levers the pressure plate away from stack of pressure and friction plates. 'slip' is induced. Purely analog anti-lock technology, and very subtle in operation. Spring tension alone dictates how much force initiates the function.
Because the wheelbase is so short, and how easy that makes it to do a stoppie on these things, the impact of having or not having a slipper function is limited in street use.
Stuffing the bike into a corner at max lean while trying to maximize pending drive out of that same corner may require a ham fisted down shift while making use of that last inch of rubber on the shoulder of the tires. Electronic quick shifters that work on a down shift exacerbate the impact......
laggy311, Strider and Gawernator like this.
post #4 of 16 Old 08-24-2019, 11:59 AM Thread Starter
davebibbs's Avatar
Thank you for such a detailed response. I really appreciate it.
Guess we will see when we get to the track 😈
QUOTE=RJ2112;1834138]1) yes
Stuffing the bike into a corner at max lean while trying to maximize pending drive out of that same corner may require a ham fisted down shift while making use of that last inch of rubber on the shoulder of the tires. Electronic quick shifters that work on a down shift exacerbate the impact......[/QUOTE]
post #5 of 16 Old 08-24-2019, 12:09 PM
The slipper is really meant to keep the chassis stable over a wider range of conditions than it would be, without. It has a much bigger impact on high compression motors with less cylinders.... a typcial Vee twin has nearly as much cc in one cylinder, as we have spread across all four. The ability of the engine to cause the rear wheel to skid is much greater, there.
The OEM unit is mostly okay -- the track day junkies and racers will tell you that more can be had, for more money. When you get into slicks, and tracks that you can use the whole thing it may be a good idea to upgrade, then. I don't think it likely I would ever need to do so, given my use.
post #6 of 16 Old 08-24-2019, 12:47 PM Thread Starter
davebibbs's Avatar
So do you still blip down on the street then? Or lean on the slipper?
post #7 of 16 Old 08-24-2019, 01:18 PM
I always blip. Habit of 30+ years. Nice to know it's there and not used, than find out it isn't when in need.
laggy311 likes this.
post #8 of 16 Old 08-31-2019, 11:42 AM
I Ride: ZX-6R 2019 ABS
I just slip the clutch on downshift. I stopped blipping the throttle with last two bikes, that I used (Tuono V4) and use now (ZX-6R 2019) on the track.
Duc995 likes this.
CyberGasty is offline
post #9 of 16 Old 08-31-2019, 04:47 PM
I made blipping a habit thanks to twist of the wrist but I do dump the clutch on some slow corners and the OEM slipper has been fine.
JL99
post #10 of 16 Old 09-02-2019, 02:08 PM
laggy311's Avatar
I Ride: Dirty
Always blip. Itís good practice. Especially after reading Twist..
laggy311 is offline
post #11 of 16 Old 09-02-2019, 02:14 PM
laggy311's Avatar
I Ride: Dirty
Sidenote:
Wtf is happening when I have to come to a quick stop, I clutch in, and my tranny makes a clicking noise? I try to downshift while stopping 99% of the time. Seems as though the tranny is never fully disconnected from the final drive? Is it chain slap (itís properly adjusted)?
laggy311 is offline
post #12 of 16 Old 09-02-2019, 05:21 PM
^^master link? Kink in chain? Bad front sprocket?
post #13 of 16 Old 09-02-2019, 05:49 PM
Originally Posted by laggy311 View Post
Sidenote:
Kinky tranny
JL99
post #14 of 16 Old 09-03-2019, 12:02 AM
The bearings on the transmission output shaft are another possibility...
post #15 of 16 Old 09-03-2019, 10:33 AM
I Ride: '12 ZX6
Hi all. First post
Two part question:
Thanks.
David.
The Kawi slippers, stock, still have a good bit of engine braking to them. You can adjust them to your flavor, but in comparison, my old flashed R6 felt like a 2 stroke when you would down shift at high RPM's (The engine would just scream more and more, but the clutch release did nothing to slow it down). You just aren't riding it hard enough and down shifting at high enough RPM's to notice it. To be honest, on a street bike, you shouldn't really notice much of a difference either, because if you are, you are cruising for a bruising.
jd41 and Gawernator like this.
WERA Expert #37
N2 Track Days Control Rider
'07 ZX6
Sportbike Track Gear
Woodcraft
Andrew Swenson Design
N2 Track Days
Otto Man is offline
