Cooling system maintenance - ZX6R Forum
 6Likes
  • 1 Post By Scorpi0
  • 1 Post By riverszzr
  • 2 Post By RJ2112
  • 1 Post By mmattockx
  • 1 Post By RJ2112
post #1 of 8 Old 08-22-2019, 11:25 PM Thread Starter
According to my 2016 zx6r manual, I need to replacement the coolant hoses and cooling system related o-rings every three years or 25,500 miles. Do you guys still replace the coolant hoses even though they look ok/new? What about the o-rings?
davidvu90 is offline
post #2 of 8 Old 08-22-2019, 11:48 PM
My '09 has all original hoses, o rings and clamps. Good or bad, that's worked for me...
post #3 of 8 Old 08-23-2019, 01:10 AM
The manual says a lotta things.
Dont let a book tell u what to do.
laggy311 likes this.
post #4 of 8 Old 08-23-2019, 10:30 AM
I routinely see bikes 10 years old and many much much older still with original hoses etc......... without issue
But, I have also seen some bikes sub 10 years old that hoses with bulges or have even burst
So while I agree with some of the timeframes in the service manual........there are some I think should be shorter and some that can certainly be longer
I imagine some of it is lawyer based and other stuff warranty based, both balanced against cost of ownership based....
post #5 of 8 Old 08-23-2019, 11:22 AM
mmattockx's Avatar
+1. My '98 looks to still have the original hoses and they are in good condition with no weathering or cracks. Mileage is low at just over 49,000km but it is still a 21 year old bike. Based on the condition of the bike I would say it was stored indoors its whole life which probably makes more difference than anything else. Bikes age fast when they live outside all the time.
Mark
1998 ZX6R
2005 KTM 450EXC
1982 GS1100E
mmattockx is offline
post #6 of 8 Old 08-23-2019, 01:55 PM
(I know I'm preaching to the choir, still a good conversation for folks lacking the background)
No matter where they are stored, eventually the compounds that make up the hose will become stiff. Almost all plastic parts (synthetic rubber, too) out gas in the same way fuel does. The smallest molecules in the blend evaporate most easily leaving the longer heavier stuff behind. The aromatics leaving the plastics in a car interior are partially responsible for the film of stuff that forms on the inside of the windshield.
As long as a hose is not disturbed, it will maintain the same seal it had when young and healthy. The older and stiffer it gets, the less flexation, and compressible it will become. Re-using an old hose or gasket reaches a point of diminishing returns where more clamping force does nothing for improving the seal. This is also true of gaskets.....
The 'redneck' solution used to be to trim off the brittle part, and re-use what remains. So long as there is sufficient slack to make the connection, it's a viable fix. Modern manufacturing does not impart significant excess, the opportunity to use this solution is ever smaller.
riverszzr and Strider like this.
post #7 of 8 Old 08-23-2019, 09:05 PM
mmattockx's Avatar
So true. If I have to pull any of the coolant hoses on the '98 I will be replacing them. They are surprisingly pliable still but there is no way I would trust it after being removed at this point.
Mark
1998 ZX6R
2005 KTM 450EXC
1982 GS1100E
post #8 of 8 Old 08-23-2019, 10:00 PM
The pliability of the fork seals...... I hypothesize that the seals need to be wetted with fork oil in order to maintain their seal. When a fork doesn't move at all for long periods of time, I believe the outer side of the seal dries out and looses its elasticity. Not a big deal in terms of days, weeks, or even months.... Certainly it takes very few years of standing to compromise them. As we're are discussing, environmental factors must also play a role.
riverszzr likes this.
