ZX6R Forum
-   -   Removing the ECU questions (https://www.zx6r.com/mechanical-technical/113972-removing-ecu-questions.html)
Sex3Sex 08-22-2019 08:44 PM
1 Attachment(s)
Hey guys, I need to remove my ECU and just have a few (possibly silly) questions. Don't like normally messing with anything electrical especially computers.
Should I disconnect the battery first? Do I need to disconnect it at all in this case?
The three connectors above the ECU, should I not disconnect them at all. Just heard somewhere not to touch them. Wondering if disconnecting them will make it easier to remove the ECU?
Thank you as always guys!
RJ2112 08-23-2019 01:15 AM
I would disconnect the battery. Just a good precaution and you're already at a point where it is accessible.
The plugs above the ECU connect to relays. Very simple devices. No harm removing the harness from them. Just make sure that you have the right plug into the right place when you hook back up.
A VERY good idea to flood each connection with dielectric grease.
Scorpi0 08-23-2019 02:09 AM
Once the battery is disconnected, u can pretty much unplug anything u want.
