Code 62, F1 light flash. Throttle clicking? [Video] - ZX6R Forum
  • 1 Post By riverszzr
  • 1 Post By MrZ
  • 1 Post By Scorpi0
post #1 of 14 Old 08-11-2019, 04:07 PM Thread Starter
Ello, so as the title says, here is a video
https://youtu.be/YJ6KY9owbm8
I check resistance and it's fine, is that movement normal?
Thanks
Linemaster is offline
post #2 of 14 Old 08-11-2019, 07:39 PM
Doesnt seem right. Heres what they should do
post #3 of 14 Old 08-12-2019, 03:45 PM Thread Starter
Hmmm... thanks for the info. I'm going to inspect the peak voltage and to from there.
post #4 of 14 Old 08-13-2019, 12:38 AM
Phill636's Avatar
I Ride: 2005 zx6r 636
That's what mine do in your video other video doesn't seem right.
Phill636 is offline
post #5 of 14 Old 08-13-2019, 02:10 AM
Who's video are u talking bout?
post #6 of 14 Old 08-13-2019, 02:32 AM
Phill636's Avatar
His you tube link in his first post
Phill636 is offline
post #7 of 14 Old 08-13-2019, 08:13 AM Thread Starter
So your saying that your subthrottle stutters like that near the end?
post #8 of 14 Old 08-13-2019, 09:01 AM
post 2 is incorrect as well........... that is not the normal function either- hell even the title of the video indicates that is a problem
they should cycle through the whole range and then stop (usually closed) but where they stop and stay until started is based on variables........air temp, engine temp, etc......... but they should never pound on the teeth of the actuator at any point in the rotation- someone probably forced by hand them to go through the travel when the motor was not turning and now it is clocked wrong
post #9 of 14 Old 08-13-2019, 12:43 PM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
MrZ is offline
post #10 of 14 Old 08-13-2019, 03:17 PM Thread Starter
Welp a peak voltage adapter is like $30, I found a throttle assy on ebay for $40 so just went ahead and got the assy. I'll install it and post an update w/ video for record. Thanks for everyone's suggestions.
post #11 of 14 Old 08-13-2019, 03:54 PM
When I hear of people buying a cheap throttle assembly on EBay, it makes me wonder where all the bad/replaced throttle assemblies end up... hopefully not on EBay!
Duc995 is online now
post #12 of 14 Old 08-13-2019, 04:41 PM
Seems like everyone's throttle bodies act differently than the others. I guess they got their own personalities
post #13 of 14 Old 08-14-2019, 05:35 PM
Jonathanhlmn's Avatar
I Ride: 2007 ZX-6R
I think code 62 is subthrottle actuator valve connection. Some may have faulty or bad connection. Some you may need to replace the throttle bodies but check the connection first
2007 ZX-6R
Jonathanhlmn is offline
post #14 of 14 Old 08-15-2019, 11:49 PM
Thanks
I had this. It wasn't any of the TPS sensors, servo motors etc, it was a faulty ECU. Changed it for another one and then all good.
I went through 3 full sets of throttle bodies to get to this conclusion.
ashintheuk is offline
