Tighten oil drain plug to 31 ft lb instead of 21ft lb - ZX6R Forum
 9Likes
  • 3 Post By Scorpi0
  • 2 Post By LiamGTR
  • 1 Post By riverszzr
  • 1 Post By Duc995
  • 2 Post By zx6rguiy
post #1 of 9 Old 08-06-2019, 02:32 AM Thread Starter
So just as the title states this is what I exactly did of course by accident. I realized my mistake and removed the drain plug and re inserted with the correct spec. Did I probably cause any damage ? Is there a chance that there is metal inside now the oil pan ? I’m wondering if I should drain the new oil just to be sure. Any thoughts ? Has anybody does this by chance. Thank you.
player07 is offline
post #2 of 9 Old 08-06-2019, 04:30 AM
Holy overraction dude!!
Your bike is fine. Nothing got damaged. Go ride!
Otto Man, RJ2112 and LiamGTR like this.
post #3 of 9 Old 08-06-2019, 05:48 AM
LiamGTR's Avatar
I Ride: '06 636
You're going to need a replacement oil diffuser, reciprocating plug, and possibly even a brand new belly pan.
All in all that one mistake has just cost you around £500.
RJ2112 and AlexFromCali like this.
LiamGTR is offline
post #4 of 9 Old 08-06-2019, 05:52 AM
When you pulled it back out- did any threads come with the bolt?
Did the threadas in the pan look fine upon visual inspection?
Did the bolt thread back in fine by hand til bottomed, then you tightened it up to proper tq spec?
finally, the crush washer, did you look at it?- overtightening them usually (always) causes them to get a groove and eventually that causes some minor oil leak whcih requires replacing said washer
me personally- I still have the oe original crush washer on my drain plug after dozens and dozens of oil changes (but I am slightly under torqued since it is safety wired anyways), but I see maybe 50-75 bikes every year with them completely crushed and grooved, some rounded right over the head of the bolt that all need replacing..........
It is not something you need to replace every oil change, but it is something to clean and look at every oil change and then replace as necessary
pic of an abused and used up drain plug crush washer.........
post #5 of 9 Old 08-06-2019, 06:52 AM
Originally Posted by player07 View Post
So just as the title states this is what I exactly did of course by accident. I realized my mistake and removed the drain plug and re inserted with the correct spec. Did I probably cause any damage ? Is there a chance that there is metal inside now the oil pan ? Iím wondering if I should drain the new oil just to be sure. Any thoughts ? Has anybody does this by chance. Thank you.
You need to learn how to hand tighten the oil drain, and not rely on a torque wrench. Thatís all that is necessary.
Scorpi0 likes this.
post #6 of 9 Old 08-08-2019, 05:41 PM
norcalzx6r's Avatar
I Ride: 2015 ZX6R 30th Anniv. 92 zx7. 92 zx7/9. 93 zx7. 96 zx7r. 00 zx7r. 01 zx7r
You're fine. Make sure to use a new crush washer every time. Don't stress.. And YES! Always torque to spec. Steel on steel is fine when hand torque by feel BUT, a Steel bolt into Aluminum Threads You tell me?
norcalzx6r is offline
post #7 of 9 Old 08-08-2019, 05:59 PM
I thought I just did!
Itís like tightening the coolant drain bolt on the water pump ... no way Iím using a torque wrench on that!
post #8 of 9 Old 08-08-2019, 08:04 PM
zx6rguiy's Avatar
The torque spec police are coming for you now buddy. 10 over and they're gonna start taking points off your license. Just put the torque wrench down and step away from the motorcycle.
RJ2112 and PhotoAl like this.
zx6rguiy is online now
post #9 of 9 Old 08-08-2019, 08:24 PM
