2009 ZX6R Help - Page 2 - ZX6R Forum
post #16 of 17 Old 08-03-2019, 01:48 AM
Actually... the manual states the voltage can range from 14.2 - 15.2 V
That's got to be allowing for cheap meters......
post #17 of 17 Old 08-03-2019, 03:36 PM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
Hey, i had the same issue as you with the gauge turning off while riding but coming on again when i reduced rpms. It was time for my stator to die.
You checked right at the battery, manual has some tests to do directly to the stator to see if it gives 54V to the r/r. Just unplug the stator from the r/r, run the bike and test with a multimeter.
MrZ is offline
