Chinese ignition switch - ZX6R Forum
post #1 of 11 Old 07-12-2019, 02:35 AM Thread Starter
Hey guys first time here, first time doing a bike build. 95 zx6r bought for less than nothing. It's in reasonable condition (unroadworthy) but has been left to rot for almost two years. Had to ditch the old ignition that had been taken to with an angle grinder. Bought a cheapo Chinese one but it's a standard 6 wire plug with an extra wire in the bundle where as mine is a 6 wire plug with only 5 wires. Wire Color used is totally different to stock plug. I was thinking that perhaps the plug was for a later model zx6r or even 9r. I'm hoping someone out in the Interweb thingy can give me a starting point to figure out what the extra wires are, and if the original wires will match up with their counterparts in the new plug. Cheers
Xceller6 is offline
post #2 of 11 Old 07-12-2019, 03:24 AM
Topper's Avatar
Found this if it's any help, ignition is in the top left.
Topper is offline
post #3 of 11 Old 07-12-2019, 05:48 AM Thread Starter
Cheers for the reply topper. Have already figured out from the manual what the wires and their relative slots in the plug are controlling am having issues with the aftermarket wiring on the new plug and the fact that it has extra wires. Are they just ad ons for extra things in later models or have wire positions of the original wires been altered as well ? Am having some other wiring issues as well and was just looking to RULE these out as the cause.
Xceller6 is offline
post #4 of 11 Old 07-12-2019, 05:54 AM Thread Starter
Actually topper thanks heaps mate. Didn't realise that I was looking at 7 wires there for a moment. What model is this from?
Xceller6 is offline
post #5 of 11 Old 07-12-2019, 07:02 AM
Topper's Avatar
Hi, says E3 on, which is the American 1995 model on but I would think it should be the same? Also noticed the wiring colours dont always match what's coming from the barrel which you mentioned?
Topper is offline
post #6 of 11 Old 07-12-2019, 07:03 AM
Topper's Avatar
Have you had no luck with getting it started?
Topper is offline
post #7 of 11 Old 07-12-2019, 07:07 AM
Topper's Avatar
I can see why why you didn't get one from the dealer lol £200 does seem a bit steep
Topper is offline
post #8 of 11 Old 07-14-2019, 06:36 AM Thread Starter
Ur right about the steep part mate. Near on $400 Over here for an oem. Considering the bike was free...... any way haven't had any luck as yet starting it. Found some other shit to fix whilst I was looking into the wiring. Cracked stator cover, leaking valve gasket, leaking sump gasket the list goes on. The manual says this bike is zx6r f3 'other than US or Canada' which I take to mean it's either a brit release or a grey import as Australia wiring doesnt match it either. Leaning towards grey. Wiring all matches up to the manual color wise and according to that im only meant to have the 5 wires coming out of the ignition so all seems as it should for now. With that diagram you gave me i should be able to nut it out. Seems theres an xtra ignition wire in there for a start.
Xceller6 is offline
post #9 of 11 Old 07-14-2019, 06:43 AM Thread Starter
No just figured it. Its the last white and yellow wire i dont have. Battery and tl3. Means a plug rewire but i think i can manage. Thanks again for the diagram mate
Xceller6 is offline
post #10 of 11 Old 07-23-2019, 05:14 AM Thread Starter
Magicdave
Xceller6 is offline
post #11 of 11 Old 07-23-2019, 05:54 AM
MaGiCdAvE's Avatar
I Ride: ZX6R 636 2002 model
if i dismantle the chinese one we should be able to compare colours
MaGiCdAvE is offline
