Bazzaz ZFI TC - ZX6R Forum
post #1 of 2 Old 06-24-2019, 04:25 PM Thread Starter
zx6rguiy's Avatar
Bazzaz ZFI TC
Does anyone know what parameters the ZFI TC uses to operate its traction control? The only speed sensor I have on my bike is the one on the front sprocket that detects rear wheel speed. I'm assuming their has to be something else that tells it that the wheels are starting to get out of line. I don't usually use the TC setting but id like to figure out how to make a push button ignition cutout that basically tricks the ZFI into thinking that the TC needs to be activated.
zx6rguiy is offline
post #2 of 2 Old 06-24-2019, 04:57 PM
Bazzazís traction control is a rate-of-change system, meaning no additional sensors or hardware are required. The module taps into the bikeís ECU and monitors engine rpm while referencing gear and throttle position to detect wheelspin, then responds by retarding ignition to cut power and regain traction
https://www.motorcyclistonline.com/b...-tc-mc-tested/
JL99
