Stripped bolt brake lever - ZX6R Forum
  • 1 Post By RJ2112
  • 1 Post By RJ2112
  • 1 Post By Sex3Sex
post #1 of 6 Old 06-22-2019, 05:08 PM Thread Starter
Sex3Sex's Avatar
Hey guys, I’m trying to remove the brake lever the previous owner installed and that little nut at the bottom that holds the screw on for the lever is stripped bad that none of my wrenches will grab it even with the adjustable wrench...
Am I out of luck? Is there a way to force it off? I tried pliers but they just slip on it.
Sex3Sex is offline
post #2 of 6 Old 06-22-2019, 06:14 PM
I usually have more luck with vise grip style locking pliers, if you're trying to hold the nut stationary.
Guessing you want to preserve the lever perch, otherwise you can cut the nut off with a dremel or hacksaw.
Sex3Sex likes this.
post #3 of 6 Old 06-22-2019, 06:21 PM Thread Starter
Sex3Sex's Avatar
I’ll try the vise grips
Otherwise I will get out the dremel and try to cut it off then just get a new nut and screw. Don’t care if the perch gets scratched up.
Sex3Sex is offline
post #4 of 6 Old 06-23-2019, 08:00 AM Thread Starter
Sex3Sex's Avatar
Got it removed with huge vise grips after applying wd-40 and a butane lighter to the nut because it was stuck on there. Perch got scratched up but nothing that some black nail polish won’t cover up.
But now wondering if anyone knows the part number for that nut?
Sex3Sex is offline
post #5 of 6 Old 06-23-2019, 09:20 AM
Originally Posted by Sex3Sex View Post
Got it removed with huge vise grips after applying wd-40 and a butane lighter to the nut because it was stuck on there. Perch got scratched up but nothing that some black nail polish wont cover up.
f the bolt survived, walk into a mom and pop hardware store and buy one that fits. Should be less than .25
Ace Hardware is one of the places that should be able to sell you just one metric nut. Probably an 8mm, 10, or 12. Get a stainless steel nut, if possible with a lock nut feature (typically a nylon insert) so you don't have to worry about it backing off. When you mount it up, only use enough force to keep the lever from rattling around.
Sex3Sex likes this.
post #6 of 6 Old 06-23-2019, 11:59 AM Thread Starter
Sex3Sex's Avatar
picked one up at ace hardware
thanks guys!
Sex3Sex is offline
