What exhaust is this? - ZX6R Forum
  • 1 Post By burke
  • 2 Post By WildCard
post #1 of 8 Old 06-09-2019, 01:01 AM Thread Starter
This is on an 05 636 so its some kind of aftermarket out the side exhaust. Also it sounds great, but I'm not sure if I'm gonna pass inspection with it.
RideZX636 is offline
post #2 of 8 Old 06-09-2019, 01:15 AM
Its a straight pipe and prolly sounds like diarrhea being spit out.
post #3 of 8 Old 06-09-2019, 06:47 AM
If it has an inspection sticker on it now, you'll likely pass again.
Agreed on it being obnoxiously loud.... if you want to fit something quieter it will be less expensive to stay with a side exit design rather than try to put it back to OEM and go out under the tail. Much less pipe involved. Simpler, and cheaper as a result.
post #4 of 8 Old 06-10-2019, 05:16 PM Thread Starter
It actually sounds great, but I'm turning the bike into a stunt bike and I read stunt bikes can't run straight pipes due to it needing some back pressure or some thing.
post #5 of 8 Old 06-10-2019, 10:33 PM
If the cat is still in the header, you have enough back pressure. Doesn't matter what the bike is used for.
post #6 of 8 Old 06-11-2019, 07:07 PM
Maybe it’s a Hotbodies exhaust or a Jardine.
Bird4 is offline
post #7 of 8 Old 06-18-2019, 02:53 PM
I Ride: 03 ZX-6R 636 , 06 DRZ400 Motard
It looks like a mid-pipe to me, that was just sawed off at an angle. Look at the rough edges.
Bird4 likes this.
burke is offline
post #8 of 8 Old 06-18-2019, 04:49 PM
WildCard's Avatar
Does it poof poof ? Or no poof poof ?
TurbineTech and Bird4 like this.
( •_•)
( •_•)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is offline
