Fault - ZX6R Forum
  • 2 Post By Ninjajosh8u
post #1 of 12 Old 06-03-2019, 10:44 PM Thread Starter
Fault
Join: 3 days ago
about 9 hours ago
Re: Engine swap
new engine is fitted now but it wont tick over and is throwing up fault code 62 check engine light is on as is the traction control light, all power mode lights flashing as is the 123 traction control. looked up the fault code and its the subthrottle valve actuator. when i took off the air box to check the valve opens when i turn on the key but when it comes back to the closed position the valve jutters like its hits the stop. if anyone has any suggestions that could help or a way to clear the code
Ninjajosh8u is offline
post #2 of 12 Old 06-04-2019, 12:28 AM
Bike?
Scorpi0 is online now
post #3 of 12 Old 06-04-2019, 03:07 AM
The sensor for the throttle positioner sounds like it needs alignment.
post #4 of 12 Old 06-04-2019, 03:26 AM Thread Starter
It's a 2013 636 how would I go about aligning the sensor
post #5 of 12 Old 06-04-2019, 03:37 AM
The shop manual for your bike is available on this site for free. Download it, you should be able to find the troubleshooting matrix, and the calibration procedure.
post #6 of 12 Old 06-04-2019, 03:44 AM Thread Starter
This is the fault code that is thrown up the valves open and when they return to closed position they jitter like they are hitting the stop around 4-5 times
post #7 of 12 Old 06-04-2019, 06:22 AM
.... so, get a multimeter, and check the resistance like the manual says.
Doesn't matter how cheap it is, so long as it reads resistance (Ohms). If there's a fault between the two sets of pins you need to measure, it will be obvious.
If the resistances both read in the 5-8 Ohm range like they're talking about, there could be some physical obstruction on the linkage that is blocking it from going all the way to one of the end points. That's what you seem to be describing. But you really need to get the numbers so you aren't just guessing on this.
post #8 of 12 Old 06-04-2019, 06:24 AM
did you get a second set of throttle bodies with the second engine?
post #9 of 12 Old 06-04-2019, 06:40 AM Thread Starter
No I'm using the ones from the old engine but i didn't have the code 62 problem before. I know they will need to be synchronized but that wont help the code 62 which is to do with the air intake butterfly
post #10 of 12 Old 06-04-2019, 07:48 AM
The sibthrottle valves do some weird movements when u first turn the key. After starting the engine, they will start working normally.
A code 62 should not prevent the engine from starting. Code 62 is easily fixed by just replacing the subthrottle assembly with a used one, which can be found for fairly cheap on ebay.
I think your main problem from keeping the bike from starting is something else though.
post #11 of 12 Old 06-06-2019, 02:14 PM Thread Starter
New throttle bodies solved the problem
RJ2112 and jd41 like this.
post #12 of 12 Old 06-06-2019, 02:16 PM Thread Starter
Just have to dial in the throttle bodies just waiting on vacuum gauges turning up in the mail
