Repairing /painting track fairings - ZX6R Forum
 5Likes
post #1 of 19 Old 06-03-2019, 09:14 AM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
Looking to fix up some track fairing I got for the low.. plan on doing some fiberglass repair where needed and then prep for paint. It doesnít have to be great.Iím pretty good at most diy stuff and Iím not in a rush so Iím going to take my time so I get the best finish I can knowing itís a track bike and it just might go down..starting this post for any tips anyone may have and to track my progress Repairing /painting track fairings-img_1081.jpgRepairing /painting track fairings-img_1085.jpgRepairing /painting track fairings-img_1087.jpgRepairing /painting track fairings-img_1204.jpg
Jdreal21 is offline
post #2 of 19 Old 06-03-2019, 09:19 AM
Feel free to peruse this thread: https://www.zx6r.com/mechanical-tech...fessional.html
JL99
post #3 of 19 Old 06-03-2019, 09:28 AM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
That post isnít coming up but I have gone threw and seen the majority of other post on the forum on the subject so I do have a general idea of how Iím going to get it done just going to post as I go so if I do have any specific questions I will already have a post on this. Should be getting some materials today if not this week to start repairing them
Jdreal21 is offline
post #4 of 19 Old 06-03-2019, 10:14 AM
My bad. Url fixed: https://www.zx6r.com/mechanical-tech...fessional.html
Either way a lot of sanding will be involved.
JL99
post #5 of 19 Old 06-18-2019, 02:57 PM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
Finally able to get some progress done . Got all my supplies and starting with some minor fiber glass repairs . It was my 1st time using fiber glass had a little hiccups but so far so good
Jdreal21 is offline
post #6 of 19 Old 06-18-2019, 03:00 PM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
Tail piece had the issue ran out of resin on my 2nd layer so it has a couple spots with air but still structurally sound enough for me taking a break for today Iíll update as I finish it
Jdreal21 is offline
post #7 of 19 Old 06-18-2019, 06:22 PM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
WildCard likes this.
Jdreal21 is offline
post #8 of 19 Old 06-18-2019, 06:25 PM
WildCard's Avatar
Looking good !
( ē_ē)
( ē_ē)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is offline
post #9 of 19 Old 06-19-2019, 07:37 AM
Looking great! If you have any technical questions let me know. Work in a body shop myself. If going the rattle can route I'd highly recommend cans from NAPA. They are about $20 each, but can get any color you want and their activated clear is about as high quality you can get without a paint gun.
Edit: We have a mixing bank so I can look up paint codes and formula for every stock color on the bike. Plastics, frame, engine, etc. So if need a match on something you just give the code to NAPA and they mix you up a can.
Blotto is offline
post #10 of 19 Old 06-19-2019, 10:19 AM
CashIs Clay's Avatar
I Ride: 2013 636
Blotto you seem to be experienced in the subject so I have a question for you. Would it be possible to use your mixing bank or one from NAPA to match my lower fairings with my side fairings? I have custom lower fairings that are flat black (same as the 2014 zx6r model) but I would love for them to match the side fairings that are Metallic Spark Black. I've included an attachment, basically I would like for the fairing circled in red to match the fairing circled in green and vice versa. Would it be possible to bring the lower fairings to NAPA and have them matched there? Or even possibly use your shop's services for that?
"Real simple, son! Cops are coming! There's a kilo of Colombian bam-bam under the car. Time to be a man. You got hair on your peaches or what?"
CashIs Clay is offline
post #11 of 19 Old 06-29-2019, 01:28 PM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
So more progress hereís the 1st bondo Filler application
[IMG]https://uploads.tapatalk-cdn.com/20190629/a2977be0bece23cccc9ee7d0e95f008c.jpg[/
IMG]
Then sanded and primed planned on being ready for paint but some spots could use some more bondo
So I marked the spots and filled them..
1st time using bondo and it set quicker than I expected and I wish I wasnít so sloppy when I applied it in some areas just a pain sanding
now they are sanded down and I think ready for paint time to watch some videos but Iím happy with the repairs so far 1st time doing this type of work and itís not so bad..
Jdreal21 is offline
post #12 of 19 Old 07-02-2019, 09:37 AM
Sorry, for the delayed response. It's not showing any alternates for the Spark Black, so it should be a great match. It's color code 169. Should just be able to give napa the code and they will mix up a can. Here is an image of what my bank calls for, but every paint line is different.
CashIs Clay likes this.
Blotto is offline
post #13 of 19 Old 07-09-2019, 07:30 PM Thread Starter
Jdreal21's Avatar
I Ride: 2015 Zx6r
Realized after sanding it was going to be more filling and sanding to make it look more perfect but I said forget it. I was just going to rattle can them anyways so I didnít waste any more time hereís after I sprayed them going to sand wet sand a little and call it a day
jd41 likes this.
Jdreal21 is offline
post #14 of 19 Old 07-09-2019, 11:55 PM
What primer did you use?
JL99
post #15 of 19 Old 07-10-2019, 04:12 AM
LiamGTR's Avatar
I Ride: '06 636
I think it's for the best you don't go for perfection, it means you wont beat yourself up too much if you ever go down. As long as it looks good from 2-3 steps back... you're good.
LiamGTR is offline
