Bike won't start when warm, and temperature readout is erratic - ZX6R Forum
  • 3 Post By Blotto
post #1 of 6 Old 05-22-2019, 06:34 PM Thread Starter
2006 ZX6R 636
Bike runs great until you shut it off. If the temperature is over 140-150 it will not restart. The temperature gauge bounces around though. Such as 175 to 189 to 176 in a matter of seconds. We have changed the coolant temperature sensor. Fan never comes on, but works with external power. Have checked fuses and relays. Have a 2nd 636 that we have swapped ECU with and same results. Have jumped all 3 connectors from the temp sensor to ground, ecu, and display, and seen no change. Also no trouble codes besides the exhaust valve that is removed. Quite stumped on what to try or check next.
Blotto is offline
post #2 of 6 Old 05-22-2019, 10:03 PM
TEmp sensor sends a signal to the ECU. The ECU will turn on the fan relay at 212 F.
post #3 of 6 Old 05-24-2019, 09:04 AM
KawasakiBrad's Avatar
Check/change the thermostat. It shouldn't have anything to do with the starting issue but could definitely cause the temp jumps.
kawasakibrad.com
KawasakiBrad is offline
post #4 of 6 Old 06-17-2019, 05:53 AM Thread Starter
Just a follow-up. I won't go into everything I went through and tried. Long story short I finally got everything fixed. The fan wasn't working because the relay pack under the tail was bad. The erratic coolant temp was because of slightly corroded ground to the frame just under the tank. The bike shutting off and not restarting once hot was because of the 4 coil packs that were replaced while doing the valves. Swapped back to the original ones and now finally running great!
RJ2112, Duc995 and KawasakiBrad like this.
Blotto is offline
post #5 of 6 Old 06-17-2019, 07:46 AM
Glad u got it all figured out. Thanks for the update man!!
post #6 of 6 Old 06-22-2019, 12:32 PM
Nedrobmas's Avatar
I Ride: Zx6RR
Was the coil packs new or used?
Nedrobmas is offline
