Stock Quick Shifter with PCV? - ZX6R Forum
  • 1 Post By jd41
post #1 of 8 Old 05-21-2019, 09:55 PM Thread Starter
hi guys, in bit of a dilemma here. I was thinking of getting a PCV unit for the '19 zx6r, I was wondering if the stock quick shifter module will work with the PCV or do I have to get the quick shifter sensor from dynojet? would bazazz work the same way?.
Thanks for the help in advance.
Rikin Sampat is offline
post #2 of 8 Old 05-25-2019, 10:33 AM
KawasakiBrad's Avatar
Short answer is Yes. The stock quick shifter will work with the PCV.
Long answer is still yes. The PCV quick shifter is an add on and requires an additional ignition module. The 2019 ZX6 PCV does not have any control over your ignition without the additional module. Adding a PCV will be a stand alone fuel control only and will not interfere with killing the ignition between shifts.
kawasakibrad.com
KawasakiBrad is offline
post #3 of 8 Old 05-28-2019, 11:16 AM
Will the stock QS work if i changed my shifter to GP shift? im used to 1up-5down shift...
kitt0y is online now
post #4 of 8 Old 05-28-2019, 12:25 PM
I don't think so. Can't find any literature on it but I'm 99% sure that's a push only sensor. Flipping the linkage to go to GP shift will orient the sensor in such a way that it will be pulled when upshifting. Won't register a kill when upshifting. But it will kill when pushed which will now be downshifting.
kawasakibrad.com
post #5 of 8 Old 05-29-2019, 07:44 AM
yes thats what happens, when you go to gp shift... it will make it QS downshifting this time...
post #6 of 8 Old 05-29-2019, 07:55 AM
can we flip the the QS the other way around if we switch to gp shift?
post #7 of 8 Old 05-29-2019, 09:03 AM
The PCV doesn't require the ignition module for QS function. The PCV standalone unitIt cuts off fuel instead of ignition for shifting.
Power Commander Quick Shifter
From STG https://www.sportbiketrackgear.com/d...r-commander-v/
The Quick Shifter is one of our most recommended mods for a track bike. This allows you to keep the throttle pinned and just step on the shift pedal to get to the next gear. Additional parts are required to enable this feature and there are options to choose from.
To add the Quick Shifter with fuel mapping: we recommend installing the Power Commander V and Quick Shift Sensor (with appropriate shift rods). No other modules are required to enable Quick Shift.
To add the Quick Shifter (cutting ignition instead of fuel) and Pit Lane Limiter: we recommend installing the Power Commander V, Ignition Module and Quick Shift Sensor (with appropriate shift rods). This will enable quick shifter and allow for more tuning options with control over ignition. With this option the ignition is cut to enable the quick shifter instead of the fuel.
KawasakiBrad likes this.
JL99
post #8 of 8 Old 06-15-2019, 06:05 PM
Woodcraft rearsets in GP allow you to do that using the stock sensor
(Woodcraft This kit is designed to use the OEM quickshifter in GP shift pattern.)
JL99
2019 quick shifter Crawfish99 The ZX6R 1 03-26-2019 04:10 PM
WTB bazzaz QS4 quick shifter Luhxe Want to Buy 0 01-18-2019 02:41 PM
Syncrotech Quick Shifter (SP) Dean93 The ZX6R 7 11-13-2018 01:47 PM
Newbie quick shifter help steve c Racing 1 12-18-2008 01:13 PM
