Finally put together and timed, issue? - ZX6R Forum
 14Likes
post #1 of 26 Old 05-20-2019, 06:39 PM Thread Starter
Flyingpapaya's Avatar
I Ride: 98 zx6r
Nm
Flyingpapaya is offline
post #2 of 26 Old 05-20-2019, 07:06 PM
WildCard's Avatar
Fixed ?
( _)
( _)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is offline
post #3 of 26 Old 05-20-2019, 08:06 PM Thread Starter
I Ride: 98 zx6r
I believe I was just miss reading everything. Turns over manually just fine, only thing is ct is at its maximum to apply tension so either I miss measured chain by a tad or intake guide is more warn than I could see through inspection but Everything seems to be in order though. So down the road when cct isn't cutting it I'll probably have to replace chain and guide or both.
Is what it is.
Still going to pull timing rotor to see if I can shave off area to remove chain without compromising the area that supports exhaust guide. If it looks like it then I'll do that when come time to change chain. If not New motor if and when.
post #4 of 26 Old 05-20-2019, 08:32 PM
Is what it is.
? It doesn't need to apply tension, it's only there to keep the chain from slapping around. This is why manual tensioners are such a bad idea......
The auto CCT simply limits the slack, rather than applying tension. Very difficult to tell where an auto CCT is actually setting itself, as they ratchet all the way out when removed. That's why they have to be reset, when reinstalled.
post #5 of 26 Old 05-20-2019, 08:42 PM Thread Starter
I Ride: 98 zx6r
You can kind of gauge with the holder set, set timing mark and remove.
post #6 of 26 Old 05-20-2019, 08:50 PM
Not trying to challenge your thinking so much as challenging mine....... How many bikes have you 'kind of gauged ' this on?
post #7 of 26 Old 05-20-2019, 09:37 PM Thread Starter
I Ride: 98 zx6r
I'm probably wrong, you guys have been the ones helping me. I just didn't feel it extend any father after setting it. Two clock wise rotations and removal.
post #8 of 26 Old 05-20-2019, 09:37 PM Thread Starter
I Ride: 98 zx6r
Maybe I'm over thinking things
post #9 of 26 Old 05-20-2019, 09:59 PM
You'll know when it's wrong, when (if) it blows up.....
Scorpi0 likes this.
post #10 of 26 Old 05-21-2019, 12:02 AM Thread Starter
I Ride: 98 zx6r
Omg don't say that lol. I'm confidant in my abilities "I retained some shot from mmi" but this is an old bike that was overly neglected. It also had a hydraulic tensioner from some random bike in it... Didn't blow up after it carb rebuild or my first valve job on it nor after the CA emissions delete. So "crosses fingers" after I get anti seize for the exhaust nuts tomorrow I'll bolt header back on then radiator/fool. Fab up a makeshift aux fuel bottle and get her running.
Still have so much to do Damn it.
Forks, steering stem bearings rebuild petcock ECT
post #11 of 26 Old 05-21-2019, 06:33 AM
While at TDC, the cam timing marks are correct on both cam sprockets
Double check, then triple check your work........ last thing you want to to be wrong on cam timing
if so then you are good to go on starting
I highly doubt you could ever extend fully any auto cam chain tensioner without the chain being broken or one of the guides completely missing (or not installing it at all)
So I bet you are only using the normal 10-15mm near the begginning like 99% are when everything is put together properly....
I see bikes all the time and when you look at 100+ cam chain tensioners a year and can see the wear marks on them from how far they travel then sit, (clicker types are often only 8-13 teeth out (1/3 max of travel) and some have finer teeth than others thus the desparity........ the hydraulic ones and those like like you show I measure them all the time at about 10-12mm and occassionally as far as 15mm out.........they can go more than 30mm out, so more than 40mm)
post #12 of 26 Old 05-21-2019, 03:56 PM Thread Starter
I Ride: 98 zx6r
Timing marks of camshafts on point, tdc 1-4, 30th link. Turned over manually multiple times and smooth as butter.
Cct installed after timing set, two full rotations and timing rechecked per manual.
post #13 of 26 Old 05-21-2019, 08:17 PM Thread Starter
I Ride: 98 zx6r
Bike runs great but now I have a fuel leak coming from I think between carb one and two.....all the carbs have done is sit on a Fucking bench. Fuel rail?
I did Prime it a few times
Grrrrrrr Fuck me
Is there gaskets for those connectors between each carb?
post #14 of 26 Old 05-22-2019, 12:57 AM Thread Starter
I Ride: 98 zx6r
Stuck float needle?
post #15 of 26 Old 05-22-2019, 02:55 AM
If you haven't already rebuilt them, bite the bullet and do so now...... ancient rubber dies when it moves. Can hold a seal until disturbed, then disintegrates. All the seals, gaskets, floats, passages....
