will a 09-12 636 engine "fit/go in" a 2015 636?? - ZX6R Forum
  • 1 Post By RJ2112
  • 1 Post By PowerGroove
post #1 of 7 Old 05-13-2019, 10:54 AM Thread Starter
Dustinwalbon's Avatar
I Ride: 03 SV650,05 636,15 636
sorry if this has been talked about. (you can point me to the thread if so)
But had a small issue with my motor, and a buddy has an 09-12 636 he has laying around, for pretty good price. I assume it would not fit. but thought I would ask and maybe we have someone here that knows more about it then I. I just ride bikes well. I don't do much else well ( =
please and thanks for help!!
Dustinwalbon is offline
post #2 of 7 Old 05-13-2019, 10:58 AM
Yes
JL99
post #3 of 7 Old 05-13-2019, 11:04 AM
Just do the opposite of this lol: Another Track build 2014 636 motor in 09 ZX6R
JL99
post #4 of 7 Old 05-13-2019, 01:18 PM
My understanding is that the ‘09-‘12 are 599 cc motors, not 636.
post #5 of 7 Old 05-13-2019, 01:22 PM
I didn't catch that. My bad. Although the y can be switched but it will require more work.
JL99
post #6 of 7 Old 05-13-2019, 06:19 PM
The block will bolt to the frame. The FI and ECU are different.
Dustinwalbon likes this.
post #7 of 7 Old 05-14-2019, 06:30 AM
The engines are identical and mount inside the frame exactly the same. That's about where it ends though. As mentioned you'll need to replace the ECU and probably wiring harness as well.
PowerGroove is offline
2013 ZX6R 636 Engine Stall Kawaii636 Mechanical and Technical 7 07-21-2019 05:16 AM
2015 ZX6R 636 30th Anniversary For Sale Johnmark101 Classifieds 7 04-20-2019 04:31 AM
2015 636 Spring Rates DARKNIGHT636 The ZX6R 2 01-18-2019 05:37 AM
2015 636 Compression adjuster on the fork DARKNIGHT636 The ZX6R 4 01-05-2019 05:52 PM
