2013 ZX6R 636 Engine Stall - ZX6R Forum
post #1 of 6 Old 05-11-2019, 09:06 AM Thread Starter
Hi Guys,
Been searching the forums but can't find any answers to my specific problem and hope you can shine a light with your expertise. Here goes:
Purchased bike from used dealership with warranty. 15,972 miles.
It is modded. Full exhaust, Two bros pipe, Power commander V, unsure of any mods inside the engine.
Has the carbon filter still installed (for the emission requirements in CA?), and no servo buddy.
Upon first day taking it home, I notice at warm up the bike idle is a bit unstable as it will rise to 2000 and drop back to 1400, rise up and then down a few times until it reaches about 150 degrees. Out on the ride the bike shuts off at speed.
35mph coming to a stop I pull in the clutch and the engine dies. RPMs sink all the way down to zero and the oil light pops up.
I get the bike restarted and head home, and I find the water pump is leaking directly on to the kickstand switch. Bike is getting extremely poor gas mileage, after a 40 mile ride I have to refill my tank.
Bike gets to the shop at the dealer and they replace the mechanical gasket in the water pump, re route the kickstand switch and replace the clutch switch, adjust the clutch lever play, and idle speed. They tell me there are no codes to indicate any faults on the bike.
Bike runs ok for 1 day and then the stalling issues return. Happens intermittently only when I am decelerating, could be when I am cruising at highway speed, slowing down for the off ramp at 50 mph, pull in the clutch and it dies.
Could be after warmup and I come to the first stop light a block away, pull in the clutch and it dies.
Could be after 30mins of riding and then slowing to a stop, pull the clutch in and it dies.
Its extremely random at this point. Bike goes back to the dealer this is now the 3rd time.
They unplug the power commander, now the bike is running lean. Gas mileage has improved I can ride approx 120 miles+ before a fill up. But the stalling issue is significantly worse and happening much more frequently.
Called the dealer and they sent me to a different shop. Race oriented bike shop. It has been there for 3 days. I called for an update:
Replaced spark plugs, removed and cleaned fuel pump, reconnect and disconnect power commander, checked valve clearances, replaced ECU. None of this has fixed the problem.
The mechanic said the dealer is sending over another ZX6R for him to pull parts off of to see if that will fix it.
Guys, Im at a loss here I don't know what to do. Can you please help? Thanks
Kawaii636 is offline
post #2 of 6 Old 05-12-2019, 12:53 AM
Has the battery been replaced?
Has the power commander been removed to verify normal operation without it?
Why don't you return the bike and get your money back?
post #3 of 6 Old 05-12-2019, 05:35 AM Thread Starter
Hi Thanks for your reply, The shop has not changed the battery but the PCV was removed and the issue got worse ( more stalling, popping on decel...although the gas mileage did improve.)
My last resort is to return the bike...I have contacted a lawyer in regards to the Lemon Law.
I would really like to fix it and was hoping someone has had a similar problem that can help me get my bike dialed in.
post #4 of 6 Old 05-12-2019, 01:32 PM
What if it needs the PCV ... but yours is defective? Taking it off doesn’t rule that out, and with the mods you mentioned i’m sure it needs a (functional) fuel controller.
BTW: this guy’s having problems too ... and found a code pointing to the ECU.
https://www.zx6r.com/zx6r/113072-help-anyone.html
post #5 of 6 Old 05-13-2019, 05:40 AM Thread Starter
I agree^^ It definitely needs a PCV and a tune. Ive read these unit are known to fail. Ill let the shop know. Thanks
post #6 of 6 Old 05-22-2019, 01:32 AM
I'd try and get your money back. I wouldn't be surprised if the previous owner traded it in because it wasn't working right.
CKwik240 is offline
2013 ZX6R 636 NonABS madmax31 Classifieds 7 05-03-2019 06:44 PM
ZX6R 636 sport tourer conversion cheeka The ZX6R 5 08-21-2018 12:48 PM
***Excellent Condition Kawasaki ZX6R - 2013, Low Miles, ABS & More*** lrrs103 Classifieds 0 08-06-2018 05:37 AM
2009 ZX6R to 636 Swap ZeeEx6Are New Member Introductions 0 06-16-2018 08:44 PM
