05 636 blowing IG fuse. - ZX6R Forum
post #1 of 7 Old 05-08-2019, 08:03 PM Thread Starter
Clepire88's Avatar
So when I replace the 10A fuse the bike will start up and idle for a moment, then pop goes the fuse. It does have a PC3 installed, it also has a woodcraft ignition bypass for racing.
I am lost, just looking to find anyone with similiar experience, or maybe someone a bit more tech savvy to tell me where to start. Sorry if this is a report, but I've viewed multiple post and the issues others have dont seem to be the same as mine.
Thank you
Clepire88 is offline
post #2 of 7 Old 05-08-2019, 08:50 PM
How long does it idle for exactly before it blows the fuse?
Scorpi0 is online now
post #3 of 7 Old 05-09-2019, 01:44 AM
Fuses let go, because the circuit they are protecting is consuming more current than is expected.
If you inspect the wiring harness very closely I would expect that you will find a point where the insulation has been compromised. That's likely causing a 'hot' wire to make contact with the frame or some other metal on the bike.
Pinched wires, or rubbing wires. Look for wear, or discoloration on the insulation or the metal it passes by.
It is a good idea to start the inspection wherever someone has modified the OEM harness. Even great workmanship can degrade over time. Bad work can go south a lot quicker.
post #4 of 7 Old 05-09-2019, 04:57 AM Thread Starter
Clepire88's Avatar
Thank you I saw one wire had a tiny slit in the insulation
post #5 of 7 Old 05-09-2019, 05:01 AM Thread Starter
Clepire88's Avatar
Yesterday after 5 minutes of riding, replaced the fuse and after idling 1 minute it died again.
post #6 of 7 Old 05-10-2019, 01:31 AM
I traced the circuit for the IGN fuse. Most possible suspects are a bad ignition coil, bad fuel pump relay, or just a short somewhere in the wiring.
post #7 of 7 Old 05-10-2019, 07:17 PM Thread Starter
Clepire88's Avatar
Its blowing the fuse without the tank hooked up, I'll look into the ignition coil or whatever that is. All major components are working. Checking CDI box and REC tomorrow. Thank you.
05 636 ecu fuse keeps blowing birchboi96 Mechanical and Technical 0 04-21-2013 09:35 AM
headlight fuse keeps blowing out the diddler Mechanical and Technical 23 01-21-2013 11:49 AM
F3 blowing main fuse kyle Mechanical and Technical 5 08-25-2012 06:41 AM
05 zx6r blowing taillight fuse Arm636 Mechanical and Technical 5 04-19-2012 05:20 PM
Blowing ECU fuse MIkyle Mechanical and Technical 5 08-15-2011 04:20 PM
