Stupid spark plug wire Q - ZX6R Forum
  • 1 Post By riverszzr
  • 1 Post By RJ2112
post #1 of 6 Old 04-12-2019, 03:21 AM Thread Starter
Flyingpapaya's Avatar
I Ride: 98 zx6r
So the boot separated from the wire. The wires inside are a little beat up. Do I just push back together? After I clean up the end or replace.
Flyingpapaya is offline
post #2 of 6 Old 04-12-2019, 05:51 AM
Snip off about 1/4" and then thread the cap back on clockwise until tight. (not heman tight, just tight)
post #3 of 6 Old 04-12-2019, 05:53 AM Thread Starter
I Ride: 98 zx6r
Ah sweet thanks. One more question if you don't mind. How do I Prime the motor for oil once I button it back up? Pull wires and turn over?
post #4 of 6 Old 04-14-2019, 12:31 PM Thread Starter
I Ride: 98 zx6r
post #5 of 6 Old 04-14-2019, 12:39 PM
Unless you took the motor apart and dried it all out..... you shouldn't need to prime it. The plain bearings will have enough of a film of oil to carry on until the pump delivers fresh. Obviously, don't rev the motor until your low oil pressure light goes out....
riverszzr likes this.
post #6 of 6 Old 04-15-2019, 01:59 AM
^ but if you really feel the need to prime it.......... You can simply crank it over in a no start condition
some bikes will crank will the kill button on kill
some will not crank then and you need to cut fuel or spark (I'd rather cut fuel so nothing is going in the combustion chamber and washing down the walls and ending up in the crankcase.....but it will evaporate away given enough run time and heat)
WildCard likes this.
A really excellent wire connecting product JimGnitecki Mechanical and Technical 6 03-04-2019 09:29 AM
Spark plug change Jamkawi1 Mechanical and Technical 3 10-11-2018 03:43 PM
another spark plug question. zxsick The ZX6R 22 06-20-2013 02:54 AM
rad fan wire help 07-08 supermn Mechanical and Technical 3 10-24-2011 11:49 AM
spark plug replacment : where are they? please help im noob! rob05 Mechanical and Technical 10 03-16-2011 10:25 PM
