Rear Shock Absorber Issue.Advice Needed. - ZX6R Forum
  • 2 Post By riverszzr
post #1 of 5 Old 04-08-2019, 12:37 PM Thread Starter
Just bought my 1st ZX6R,but worried about the rear suspension.
It's a '96 F2.The hose from the reserve cylinder/pre adjuster had been loosened from the shocker absorber.It is leaking fluid of some sort.And,I'm unsure but aren't these pressurised too?
What do I need to do to correct this?
Does it need to be filled with some sort of fluid and or re pressurised maybes with either nitrogen or air?
Or would be easier to replace?And would a one from maybes later models fit,as they are available more cheaply.
All advice appreciated.
Thankyou
Markos is offline
post #2 of 5 Old 04-08-2019, 04:47 PM
Replace, or rebuild.
Words to live by
post #3 of 5 Old 04-08-2019, 07:25 PM
The oil is in one location. The pressurized bladder is seperate from the fluid, (ie...the nitrogen and the oil do not intermingle).......but...
You need to tighten the fitting to stop the leaking, but depending on how much oil leaked out, the bladder will be extended and pressure will be low as will the oil leavel
So refresh/rebuild or simply spend the money and replace it with something far newer and better......?
If you have a suspension person local, lots of time you get get fresh oil, seals and nitrogen refill for around $125
RJ2112 and Strider like this.
post #4 of 5 Old 04-09-2019, 05:38 AM Thread Starter
Thankyou
Markos is offline
post #5 of 5 Old 09-19-2019, 12:49 AM
Juda Tjoa's Avatar
Hey guys I have a question if a '09 shock fits on my zx6r '03? And if so, do ai need the linkage too?
Juda Tjoa is offline
FS: 09-12 Racetech G2-R Forks & Elka Stage 4 Rear Shock Dougie Fresh Classifieds 11 10-07-2019 01:31 PM
Rear brake reservoir tank cover needed? rogal88 The ZX6R 1 03-21-2019 12:10 PM
Rear shock help Brandon35 The ZX6R 7 02-05-2019 07:33 AM
ZX6r B1h and P8F Rear shock compatability ninja44 Mechanical and Technical 2 09-25-2018 10:13 AM
Rear Shock B1H stevewyatt69 The ZX6R 3 01-24-2009 09:38 AM
