Fuel Lines 201e zx6r - ZX6R Forum
post #1 of 7 Old 03-26-2019, 05:30 PM Thread Starter
swampfox676's Avatar
I Ride: 2012 ZX6R
Hey guys,
Referred to my service manual first. It's been months and I cannot figure out how to reconnect the two fuel lines coming off of my tank. It's not a Cali model and the fuel pump is already hooked up properly, it's just the two fuel lines coming off of the tank. All I know is that one of them is a run off line. Thanks. A picture of where to connect it would be greatly appreciated..
swampfox676 is offline
post #2 of 7 Old 03-26-2019, 05:52 PM
Dean93's Avatar
I Ride: 2013 ZX6R ABS
By the picture it looks like you're almost there lol, just get those rubber hoses on there and secure it with the clamp.
EDIT
I've found some pics of mine that shows one of them connected, other one should be the same, hope it helps.
Dean93 is offline
post #3 of 7 Old 03-27-2019, 02:27 AM
Both just thread through the frame to drip on the ground. One is the tank vent, the other is the drain around the filler neck. Pretty sure the vent is the left one.
Either way, you want to make sure the hoses aren't kinked, blocked or pinched when installed.
post #4 of 7 Old 03-27-2019, 01:21 PM Thread Starter
I Ride: 2012 ZX6R
So both of the hoses coming off of my gas tank are run off lines? Meaning they dont attach to anything? Just run them so that they are clear and unkinked to the ground?
post #5 of 7 Old 03-27-2019, 04:38 PM
Yes.
post #6 of 7 Old 03-27-2019, 09:30 PM Thread Starter
I Ride: 2012 ZX6R
Last question. The fuel seperator that the two lines run to is only for CA models only correct? It's not specific in the manual. Thanks guys.
post #7 of 7 Old 03-28-2019, 02:11 AM
CA only.... The third line your tank does not support, is involved. For yours, two lines aimed at the ground.
Where do you connect the fuel lines from the fuel tank on a 12' ZX6R? swampfox676 Mechanical and Technical 8 03-26-2019 05:21 PM
2016 ZX6R won’t Rev with low fuel Shawn Alger Mechanical and Technical 10 03-11-2019 06:50 PM
ZX6R 2010 wont start fi light on no fuel pump sound kawaz550gp Mechanical and Technical 2 11-15-2018 02:11 PM
02 Zx6r massive fuel leak matt6247 The ZX6R 6 06-23-2018 09:35 AM
? s about vac and fuel lines 95 zx6r osageinmt The ZX6R 14 04-07-2011 05:57 PM
