fork service - Page 5 - ZX6R Forum
 55Likes
post #61 of 76 Old 05-12-2019, 04:11 PM
I Ride: ZX6R J2 VFR 800 FI1
Thanks for your quick reply.I,ll get them done tomorrow
tenko is offline
post #62 of 76 Old 05-12-2019, 06:09 PM
A physical hieght measurement after you thoroughly and fully stroke the cartridge atleast 10 times or until no more air gaps in the stroke (you can feel them) and have also stroked the fork tube through a dozen or so 4-5" full strokes as well then let it sit for about 10 minutes
110mm level of 7w works well on these if running all stock oe components
RJ2112 and laggy311 like this.
post #63 of 76 Old 05-12-2019, 06:45 PM
laggy311's Avatar
I Ride: Dirty
Seriously though. Why 110mm? Would that make a softer ride?
Yo momma so fat, Thanos had to snap twice.
Sitzpinklers
laggy311 is online now
post #64 of 76 Old 05-13-2019, 12:11 PM
Oe set up has a shit ton of spring pre-load built in to them just assembling them, and you can't change that unless you buy new springs...
So they feel super stiff when you are checking sag etc, but in actuality they are pretty soft
having the oil level higher (110mm is a higher oil level than 115mm) actually aids in the "air shock" near the end of travel and slow down the fork speed and usually can prevent you from bottoming them out
the oil level mostly only affects the final 25-35mm of fork travel- everything else (90% of the riding time) the oil level as long as it is sufficient enough, has no affect.......... it is basically adding some progression to the air spring, since there is air above the oil and when you stroke through travel you can't compress the oil, but you do compress the air
There are plenty of bikes that once you add emulators, or different cartridges/valves or springs that you actually want to run a lower oil level than oe
ie.......... some oe are like 90mm oil level, they go up to 120mm with many aftermarket parts so the spring and valving are doing more of the work
post #65 of 76 Old 05-14-2019, 03:01 AM
laggy311's Avatar
I Ride: Dirty
Blah blah...experience..blah blah
Jk! Genius. That's awesome info. Packing that away for sure.
I want to troll and find people that battle you....
Sitzpinklers
post #66 of 76 Old 05-14-2019, 11:31 AM
fucking troll it all you want
No doubt you can find some fucktard somewhere to disagree
but ask some suspension experts............ then go back and troll the trolls
laggy311 likes this.
post #67 of 76 Old 05-14-2019, 11:40 AM
laggy311's Avatar
I Ride: Dirty
Is this type of thing found in the Racetech suspension bible? Seems like once you understand, you can tweak depending on model of bike.
Sitzpinklers
post #68 of 76 Old 05-14-2019, 11:44 AM
Yup. Here's an ohlins chart on how oil level affects travel
Name:	oil spring nix30.jpg
riverszzr likes this.
JL99
post #69 of 76 Old 05-14-2019, 04:27 PM Thread Starter
......I damaged my seals, installing them. Now I know better.
The question is, can I just replace the seals?
All of the bushings have 70 miles on them. Brand new dust boots, too.
post #70 of 76 Old 05-14-2019, 05:06 PM
yes
riverszzr and RJ2112 like this.
JL99
post #71 of 76 Old 05-14-2019, 10:50 PM
The motion pro bullet fitment sometimes doesn't cover the inner lip so it can damage the seal. I wrap electrical tape to the area that is not protected to help with that.
JL99
post #72 of 76 Old 05-15-2019, 12:58 AM Thread Starter
Yeah, I was pretty disappointed with that. I specifically bought the bullet to prevent that damage. Without having done the service, I didn't recognize the shortcoming in the design.
I find humor in the thought of using a condom over the bullet to smooth that transition.
Electrical tape seems like a good option, Teflon tape seems like it would be better....... Softer, and more malleable. Any kind of tape, seems like residue could be an issue.
post #73 of 76 Old 05-15-2019, 07:36 AM
I have never had any residue issue
electrical tape all the way, the cheap stuff even.......... 10 pack rolls for 3.99
it is on there such a short amount of time, sub 30 seconds and the fork tube is cold typically............(room temperature cold anyways)
teflon tape works but you have to double it up and it does tend to roll with the seal, plus it costs more........more cost, more pain in the ass............. fuck that shit, go with the electrical tape!
post #74 of 76 Old 05-15-2019, 08:16 AM
Oh, and make sure you grease up the seals prior to install.
JL99
post #75 of 76 Old 05-15-2019, 11:14 AM Thread Starter
I even bought, and used the motion pro seal grease..... that $%## gap after the bullet did me in.
riverszzr and jd41 like this.
Bent Shift Fork? leecasey Mechanical and Technical 10 01-05-2012 12:35 PM
Bolt in Fork bottom won't tighten 07 ZX6R motodug Mechanical and Technical 0 06-18-2011 08:46 PM
Service History tafferel69 The ZX6R 5 09-04-2009 01:23 PM
