Jesus Christ help. Horrible top and noise - Page 2 - ZX6R Forum
 31Likes
post #16 of 58 Old 02-24-2019, 04:13 AM
Rivers is telling you to go ahead and pull the head. I agree. You have something like a 5% chance that you won't need to.
HemiDave likes this.
post #17 of 58 Old 02-24-2019, 04:22 AM Thread Starter
Flyingpapaya's Avatar
I Ride: 98 zx6r
I know... If the valves are bent I'm Fucked and out of a bike again for at least a year.
Flyingpapaya is offline
post #18 of 58 Old 02-24-2019, 05:19 AM
Why?
Getting a competent machine shop to mill the head, and do a valve job isn't going to be many thousands of dollars.... I haven't had to have anyone do that sort of work in a long time so my numbers are wildly low. Presuming you can hand them the complete head, it's not that many hours to do the machining. If the pistons are whacked, and the bottom end is wasted, another motor is far less money. You'll find that out when you pull the head....... or look at the oil as has been mentioned before.
The further you can take it apart, the less hours the shop has to charge you. Eventually you need to know what you can or cannot do. Money is time. Yours costs you less than the shop's time.
If you drop off the complete bike, it's probably totalled. Worth more for the parts than the running bike would be.
post #19 of 58 Old 02-24-2019, 09:59 AM
mmattockx's Avatar
Looks like it jumped a couple teeth, the timing was off.
If it jumped two teeth I would be amazed if it didn't have some bent valves. I also find it surprising that it would idle in that condition, it was hard to tell in your video but it didn't sound like it was dropping cylinders and there is no way all 4 should have been firing.
Do a leakage test!
+1. If OP isn't going to pull the head immediately a leakdown test is the minimum to do.
Mark
1998 ZX6R
2005 KTM 450EXC
1982 GS1100E
mmattockx is offline
post #20 of 58 Old 02-24-2019, 06:10 PM Thread Starter
I Ride: 98 zx6r
I should be able to get a hold of the equipment for a leak down. Borrow my brothers compressor.
post #21 of 58 Old 02-27-2019, 05:39 AM Thread Starter
I Ride: 98 zx6r
Changed my mind, I'm just going to pull the head.
RJ2112, WildCard and HemiDave like this.
post #22 of 58 Old 02-28-2019, 10:36 PM Thread Starter
I Ride: 98 zx6r
The manual says drain coolant before. I generally follow what the manual says to a t but looking for some input. Is it required
post #23 of 58 Old 03-01-2019, 02:31 AM
Depends on how much of a mess you can tolerate where you're working...... Top of the radiator is above the bottom of the head. When you break the seal on the cooling sytem, what is above that point will drain. Probably into the engine as well as the floor.
post #24 of 58 Old 03-01-2019, 09:22 AM
mmattockx's Avatar
I would drain the coolant to pull the head. To check valves you can simply unbolt the rad and drop it forward for access to the engine, but pulling the head opens the cooling system up and will spill coolant all over the place. It only takes a minute to drain the coolant and saves a lot of mess all over your shop floor. Catch it in a bucket and reuse it if you don't want to put new coolant in after.
Mark
1998 ZX6R
2005 KTM 450EXC
1982 GS1100E
post #25 of 58 Old 03-01-2019, 10:18 AM
If you are actually pulling the cylinder head off the engine, you must first remove the engine from the chassis.
So exhaust, carbs, electrical connections, chain off, shifter off, oil drained, coolant drained (and I would go as far as pouring through a gallon or more of distilled water to clean out most the glycol- because it will still be a mess after draining)
post #26 of 58 Old 03-07-2019, 04:40 PM
Brandon35's Avatar
Just based on what you've said about the timing having jumped, I'd say like others have that it's going to be 100% some bent valves if not broken. I had a slight timing lag on another bike and that one made a nice gouge in the piston head but surprisingly didn't break the valve (but bent the hell out of it). If money is tight (I know how that is), you're probably far better off shelving that motor for a later project and throwing in a low miles/rebuild engine from a forum member or online. It's both a beast of a job if you don't have the tools for a top end rebuild plus the machining costs. Hoping you get lucky though.
WildCard likes this.
Brandon35 is offline
post #27 of 58 Old 03-23-2019, 11:29 AM Thread Starter
I Ride: 98 zx6r
Pulled the cylinder head, no visible damage to pistons or valves. Tested to see if any leaked by filing with carb cleaner, all good except cylinder 1 first intake.
My guess is its just old.
Could I just lap the valve after removing it and reinstall check for leak? I think it's just carbon buildup from age. Thoughts?
post #28 of 58 Old 03-24-2019, 05:20 AM
WildCard's Avatar
I would clean up the valve first with some Berryman's to get rid of the carbon and see if that fixes the leak assuming everything else looks good, but i'm just a shade tree hack.
@riverszzr is the hero we need for the REAL answer.
( _)
( _)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is offline
post #29 of 58 Old 03-24-2019, 06:23 AM Thread Starter
I Ride: 98 zx6r
Aside from buying an actual spring compression tool any of you guys use c clamps to compress a valve spring so I can get to the keepers?
post #30 of 58 Old 03-24-2019, 06:32 AM
WildCard's Avatar
I would get an actual spring compressor tool. Unless you modify the c-clamp there won't be much of the foot actually making contact. Good way to damage something or lose parts/an eye.
( _)
( _)>⌐■-■
(⌐■_■)
Roads. ☢
WildCard is offline
