2013+ Air Duct access? - ZX6R Forum
post #1 of 6 Old 12-03-2018, 04:13 PM Thread Starter
Cam0101's Avatar
Hi all,
I have been following Mr Kawasaki's build and something has been making me wonder.
The 2013+ airduct, is there a way to access it without taking off most of the bikes fairings?
Want to remove some of the sound deadening.
2016 - Kawasaki - ZX-6R 636 (ABS)
Rear Wheel 130HP / ~97kw & 53ft-Ib / ~71nm
Mods: Two Brothers S1R Slip-on Exhaust, Decored OEM headers, LED lighting conversion (Headlights, Markers, Indicators), TST Industries Taillight light and TST Industries Fender Eliminator
Woolich Racing ECU Tune w/ Race Tools: Quickshifter, Launch Control & Pit Limiter
Planned Mods: Braided Brake Lines
2016 - Kawasaki - Z125 Pro
Mods: Yoshimura RS-2 Exhaust, Airbox delete with Short Ram Intake with Pod filter and LED Headlight and Markers Conversion
Cam0101 is offline
post #2 of 6 Old 12-03-2018, 04:40 PM
Most of the foam is inside the air box. The duct itself has none.
Words to live by
post #3 of 6 Old 12-03-2018, 06:28 PM
whats the purpose of removing the sound deadening?
A1_Digest is offline
post #4 of 6 Old 12-03-2018, 07:43 PM Thread Starter
Cam0101's Avatar
True that most of the foam is in the airbox, there is still some in the airduct between the front cowl and frame. There is also a tube as well that is in the way.
Cam0101 is offline
post #5 of 6 Old 12-04-2018, 02:03 AM
....you said you wanted to remove 'some' of the foam.....all, you'll need to take it apart more than you seem to want to.
Why you would want to, hasn't been discussed. More noise?
Words to live by
post #6 of 6 Old 12-04-2018, 02:59 AM Thread Starter
Cam0101's Avatar
Mainly for min maxing. plus I wanted to remove small bug debris that had gotten past the grill, but not to the airbox. I was already having the tank off and just wondered if it was possible to do without removing majority of the fairings.
It is possible to do AirDuct though the airbox although a tight squeeze around the steering head.
Cam0101 is offline
2013 636?!!!! Loomie The ZX6R 836 10-19-2015 06:14 AM
2013 Releases: Kawasaki oKayH Motorcycle Talk 39 07-12-2012 09:22 PM
Clean air mod. wiffy The ZX6R 13 01-29-2010 11:29 PM
