Caliper Rebuild Kit - ZX6R Forum
  • 1 Post By jd41
post #1 of 12 Old 08-20-2018, 10:10 AM Thread Starter
dkolbasovsky's Avatar
I Ride: 2003 ZX6R
Caliper Rebuild Kit
Hello,
Trying to source caliper rebuild kits for my 2003. My usual sources don't have any, I am in Canada but I can buy from US if needed. Where are you getting your rebuild kits?
dkolbasovsky is offline
post #2 of 12 Old 08-20-2018, 11:50 AM
I order through bikebandit.com the individual oem parts need. Maybe check EBay for a completeĒkitĒ ; however, might be hard to judge quality.
post #3 of 12 Old 08-21-2018, 10:18 AM Thread Starter
I Ride: 2003 ZX6R
Thanks, I was hoping for a quality complete kit if possible. OEM is a bit pricey.
post #4 of 12 Old 08-21-2018, 10:21 AM
All balls kit #18-3145
Duc995 likes this.
JL99
post #5 of 12 Old 08-21-2018, 02:04 PM
Pricey...true. But we are talking about a critical component that needs to function flawlessly.
I went OEM, but Iíll be curious what you eventually find myself!
post #6 of 12 Old 08-23-2018, 08:27 AM Thread Starter
I Ride: 2003 ZX6R
This looks like it will do the trick! Have you used it?
post #7 of 12 Old 08-23-2018, 08:35 AM Thread Starter
I Ride: 2003 ZX6R
Can I ask what you paid to do it this way? Looking at Partzilla the OEM parts will be $134+ per caliper. I'd be looking at $400 CDN for the pair.
post #8 of 12 Old 08-23-2018, 09:09 AM
I've only used their steering stem bearings and MC rebuild kits. No problems so far. Make sure you use red rubber grease or Syl-Glide Silicone Brake Lubricant.
A few tips to keep in mind while rebuilding brake calipers.
JL99
post #9 of 12 Old 08-23-2018, 09:29 AM
Iíve always been told to use only brake fluid to lubricate brake seals. The grease products will contaminate the brake fluid, and attract dirt.
post #10 of 12 Old 08-23-2018, 09:38 AM
On Bikebandit.com I spent $117.70 US for the 8 seals, 8 dust seals, and two caliper-half joining seals; enough to replace the rubber components of both front brake calipers.
post #11 of 12 Old 08-23-2018, 09:45 AM
I use it on the rubber seals only for assembly. I've used it once on the caliper pistons and it was a mess, so I agree with you on that. It's safe to use with brake fluid. Brembo includes a pack with its rebuild kits.
JL99
post #12 of 12 Old 08-23-2018, 09:51 AM Thread Starter
I Ride: 2003 ZX6R
Thanks!
Kit parts creeper6 Racing 0 08-14-2018 10:36 AM
Caliper Rebuild tomoney Mechanical and Technical 6 10-11-2011 03:44 PM
05/06 fork rebuild kit???? luke174 The ZX6R 1 11-05-2010 09:56 AM
