ZX6R Forum
-   -   Caliper Rebuild Kit (https://www.zx6r.com/mechanical-technical/110838-caliper-rebuild-kit.html)
dkolbasovsky 08-20-2018 09:10 AM
Caliper Rebuild Kit
Hello,
Trying to source caliper rebuild kits for my 2003. My usual sources don't have any, I am in Canada but I can buy from US if needed. Where are you getting your rebuild kits?
Duc995 08-20-2018 10:50 AM
I order through bikebandit.com the individual oem parts need. Maybe check EBay for a completeĒkitĒ ; however, might be hard to judge quality.
dkolbasovsky 08-21-2018 09:18 AM
Thanks, I was hoping for a quality complete kit if possible. OEM is a bit pricey.
jd41 08-21-2018 09:21 AM
All balls kit #18-3145
Duc995 08-21-2018 01:04 PM
Pricey...true. But we are talking about a critical component that needs to function flawlessly.
I went OEM, but Iíll be curious what you eventually find myself!
dkolbasovsky 08-23-2018 07:27 AM
This looks like it will do the trick! Have you used it?
dkolbasovsky 08-23-2018 07:35 AM
Can I ask what you paid to do it this way? Looking at Partzilla the OEM parts will be $134+ per caliper. I'd be looking at $400 CDN for the pair.
jd41 08-23-2018 08:09 AM
I've only used their steering stem bearings and MC rebuild kits. No problems so far. Make sure you use red rubber grease or Syl-Glide Silicone Brake Lubricant.
A few tips to keep in mind while rebuilding brake calipers.
Duc995 08-23-2018 08:29 AM
Iíve always been told to use only brake fluid to lubricate brake seals. The grease products will contaminate the brake fluid, and attract dirt.
Duc995 08-23-2018 08:38 AM
On Bikebandit.com I spent $117.70 US for the 8 seals, 8 dust seals, and two caliper-half joining seals; enough to replace the rubber components of both front brake calipers.
jd41 08-23-2018 08:45 AM
I use it on the rubber seals only for assembly. I've used it once on the caliper pistons and it was a mess, so I agree with you on that. It's safe to use with brake fluid. Brembo includes a pack with its rebuild kits.
dkolbasovsky 08-23-2018 08:51 AM
Thanks!
