05 zx6r from blue to orange - ZX6R Forum
post #1 of 14 Old 03-29-2019, 02:16 PM Thread Starter
Talking 05 zx6r from blue to orange
Got my 05 zx6r back in '15, extended lowered and look'n fine. After a year took the extension off and raised her back up. This year I pulled the trigger and started a refresh of the old'gal. Dent in the tank oil all over the left side of the engine not making as much power as she use to, Ordered new orange fairings from Auctmarts they should be coming within the next month, took off the old ones thats when I decided to order new gaskets for the whole engine.Early this week got the engine pulled and now just waiting for gaskets to arrive so i can tear the engine apart clean it and get her ready to go together. While I wait ill just do little things, prep the new radiator, cleaned the exhuast, clean the frame on a nice day, get new clutch ready to install and fit the new hoses on. Let me know if you want to see a part of this teardown and rebuild ill try to get pics of everything in case someone is wanted a visual on how to.
Cody Copple is offline
post #2 of 14 Old 03-30-2019, 11:44 AM
Definitely want to see. Go for it and good luck
venom is offline
post #3 of 14 Old 03-30-2019, 07:01 PM Thread Starter
Thanks, Ill post more as the last of the parts come in.
post #4 of 14 Old 03-31-2019, 07:15 AM
mlsracer's Avatar
I Ride: 2009 CBR1000RR
Following. Good luck man. Love threads like this.
Sent from my SM-N960U using Tapatalk
mlsracer is offline
post #5 of 14 Old 03-31-2019, 07:15 AM
mlsracer's Avatar
mlsracer is offline
post #6 of 14 Old 04-01-2019, 04:56 PM Thread Starter
Got the engine cleaned before i tear it apart for a deeper clean and inspection, Got email that the new fairings are shipping soon and all gaskets are shipping. Only thing to do now is order filter and battery then ill be on my way.
post #7 of 14 Old 04-01-2019, 05:07 PM
mlsracer's Avatar
Looking good! What'd you use yo clean them up?
mlsracer is offline
post #8 of 14 Old 04-02-2019, 07:29 PM
ZedExMuse's Avatar
Well done Cody. I applaud your thorough attention to detail. You clearly have started on the right foot. Please keep up the very good work, and keep the very good pictures coming, too!
C8H10N4O2
ZedExMuse is offline
post #9 of 14 Old 04-02-2019, 08:22 PM Thread Starter
Thanks Zed, i will. mls i just use engine degreaser and carb cleaner for now. Used CLR for the exhaust might try it on some other parts.
post #10 of 14 Old 04-05-2019, 07:33 AM
mharrison's Avatar
I Ride: 1999 zx6r
Off to a great start! Not many people are willing to dig in like you have!
Aside from gasket replacement are you planning to do to anything with the engine while you have it out? Valve adjustment, valve seals, new rings and bearings, etc?
mharrison is offline
post #11 of 14 Old 04-05-2019, 04:03 PM Thread Starter
I have reason to believe that the bike had a valve job less then 7k miles ago before I bought it, I'm going to check valve clearance and visually inspect the rest of the bike but if it looks good I might skip putting new rings, seals or anything else in it this year as my funds are running low again, as I thought 500 in new plastic was all that was going to happen not 4k in parts and misc things lol but I did get the headlights restored since the weather has been rain in Iowa this week, gaskets are all in and now motor teardown is planned for Monday due to it's not suppose to rain
post #12 of 14 Old 04-06-2019, 04:47 PM Thread Starter
Painted exhaust today before the clouds came. Coolant hoses were dropped off got a bit of cleaning done on the frame and battery box. Can't wait for monday hope to have the engine back on the frame
post #13 of 14 Old 04-10-2019, 09:27 AM Thread Starter
Got some work done Monday, most of the bike is back on just some small things I have to get on before I test if it will even run again
post #14 of 14 Old 04-18-2019, 10:18 AM Thread Starter
Clutch wont engage, everything is going together snug no play between plate and friction plates, am i just stupid or is this a bigger issue :
Zx6r 1998 blue smoke Konstantin Mechanical and Technical 9 09-07-2018 05:11 PM
My Matte Blue '06 ZX6R cameradude Pictures 39 10-21-2009 06:10 AM
New 2008 ZX6R Plasma Blue Ninja6RALu The ZX6R 18 07-09-2009 07:56 PM
