My '96 Rebuild
19K views 223 replies 11 participants last post by  Brandon35
#1 · (Edited)
'96 Rebuild
Hey guys, been a while. So, after a long time coming, I was finally able to start my rebuild. She’s come a long way since the start but I figured while I wait for more parts (and money) I’d post about it.
Quick history - bought the bike 6 years ago, found out it had a LOT of issues, started to fix a few things here and there, turns out I was really good with zip ties. Bike was in at least one bad front end accident (no steering stop, small crack in frame). She had the scars to prove it. So much so that I’ve never considered taking her to a shop to get looked at because I would have been pretty embarrassed. Anyways, this last couple of weeks I had some free time (yay Thanksgiving) and set about a teardown. I’ve had second gear issues for a while now.
So, I start to break down the bike. Crappy fairings off, took the airbox and carb off (everything was filthy and the throttle springs were covered in filth). Then I freed up all the electricals and took the whole harness out. Had to make some cuts and I’ll connect those back up for the tail/blinkers later. Then came the engine. I had no lift, so I paid $1 at Lowes to take 3 pieces of old wood from a trash can and made an engine holder out of it. It’s actually held up quite nicely. Once I had the engine out, I stripped the frame all the way down and cleaned EVERYTHING. She had 22 years of road grime in all her nooks and crannies. I used Nylon brushes and my favorite degreaser (La’s Awesome Degreaser is really awesome) to do it right. I’ll list off the fixes/upgrades I’ve done so far and leave pictures for those of you who can’t read ?
-Re-wrapped seats
-Cleaned Engine
-Rewrapped wire harness
-New fork oil, caps and seals (pretty sure it had original oil and boy, it was solid)
-New (to me) left fork
-Had the frame crack welded and I grinded it
-Had the steering stop re-welded on
-Polished yoke
-Painted the entire frame satin black
-Painted my rims white
-Cleaned out all my brake calipers
-New brake pads (new rear seal kit coming)
-Stainless steel lines front and rear (used off a working race bike - haters gonna hate)
-All new engine cover Cometic gaskets
-New (to me) drive shaft/gears and clutch shaft forks (I split the case)
-Driven racing engine block-off plates
What’s to come -
-2006 zx6r throttle tube assembly/cables
-Slim kill/start switch
-Steel extension plates for my zzr600 fairing stay (bird cage delete) so handle bars don’t hit
-New tires (I’m thinking Dunlop Q3+ ?)
-Safety wiring
-Race fairings down the road (belly pan w/oil catch) ~ when money allows :nerd
-Airbox/tubing upgrade ~ when money allows
#3 ·
So far, so good Brandon. How about the wheel bearings, steering neck, and swing arm bearings? Hopefully you'll never be this deep in the bike ever again.
Off this topic, did you get the platform you wanted? Did SERE s*ck As much as I think it did? ;)
#4 · (Edited)
Off this topic, did you get the platform you wanted? Did SERE s*ck As much as I think it did? <img src="Racing" border="0" alt="" title="Wink" class="inlineimg" />
Yeah I checked all the bearings and re-greased them - none of them were grinding or looked worn/bad. I just hope the fix worked! As a side note, This is the third time my sprocket nut has been super loose so i need threadlock and really torque her down.
As for good old Ft. Rucker, SERE was definitely not the most fun, but it was a good learning period. I’ve actually been on hold for a while waiting for common core to start (lots of people here).
#5 ·
Bled the front brakes tonight (rear rebuild to come) and everything I saw online was telling me to get a vaccum thingy. I didn’t, and it was still a piece of cake. Not sure if the ss lines make it easier, but after getting straight fluid and no air (and no lever pressure), I cracked the banjo bolt at the master cylinder and a ton of air came out. Soon as I did that I got brake pressure. Didnt take much time at all, things are starting to come together.
#8 ·
Having a hard time figuring out why my triple tree always wants to be turned slightly to the right when the alignment gets done for the forks. The forks are straight, everything seems to line up and the wheel spins nicely, yet the triple tree is consistently off-center. Steering stem bearings seem fine, no wiggle and no binding. Thoughts?
#12 · (Edited)
Some updates Fellas.
Had to take the engine out and split the case again - turns out one of the forks had fallen before I had everything tight and it got wedged off of the shaft :coocoo fixed that. Put the engine back in and she shifted like butter.
Next, I upgraded to an 06' throttle assembly, had to add a few silicone washers for the longer length but overall not a bad fit, and much much better than the old start button throttle assembly. Wired in a thin start/kill switch and drilled some holes for them to sit in perfectly. Should probably take a picture of that instead of the cables going over the res.
Completely rebuilt the rear brake - new seals and all. She needed it (broke a seal on disassembly).
After that, I re-upholstered my seats with some walmart fabric. Not a bad job if you use a heat gun and take your time.
Lastly, not pictured is the safety wiring I started. Drilled a hole in my oil drain bolt and wired that and the oil cooler banjos. Also did my oil filter. I'm thinking once I do my tires I'll wire the brakes.
I have a new (to me) lower yoke with good bearings to put on once I buy my tires, front and rear wheel bearings, and new bolts all around. That should straighten my front end out. After that, the only thing left is to buy track fairings well down the road when I have another, newer bike to use on the street.
#14 ·
Once I fixed the fork caps and did my oil flush job, I sprung the front for my weight. I believe the rear was good to go for my weight already, but I plan on checking again after my tire change.
Reactions: RJ2112
#15 ·
Yesterday I did a thing. Never had the correct front fender so I ordered a used one to paint. Found out after a deep clean that it has severe cracks all around each bolt hole, so I used my cheapo soldering iron and did some plastic welding. Think it turned out alright in terms of strength and now she’s looking good.
I sanded the front fender and my new rear hugger (found out it was real carbon fiber, bought on ebay from a guy who didnt need it - it needs some holes drilled still) and painted them satin black. Did some wet sanding before a final coat to really bring out the smoothness. I’ll save the install for my new Q3+’s, wheel bearings and new (to me) lower clamp.
Reactions: WildCard
#16 ·
Very cool! Track bike or commuter bike? i have a J2 (2001). They share a ton of parts. I did block off plates, jet kit and timing advancer! Why did you go with the 05 throttle cables and tube? shorter throw?
#17 ·
Commutter for the time being, hoping to get on the track once I have the time to do so. I went with the 05 throttle because my old throttle assembly spun on the bar and the 05 was external to the starter assembly. The 05 cable is slightly longer so I had to use rubber washers as spacers but it functions way better than my old assembly did and is much more solid too.
#18 · (Edited)
Update: this weekend I replaced all my wheel bearings front and rear with an All-Balls set, installed the new (to me) lower yoke with new bearings and plenty’o grease, and installed my new (to me) front fender and carbon fiber (painted black) rear hugger.
The tires were the worst mistake of my life in terms of doing it myself... took me all day yesterday just to get them on the rim (ruined my paint job in the process of course but I’ll fix that later), and could not for the life of me get the bead to fully seat. Took it in this morning and five minutes and zero dollars later I had filled tires. The cornering characteristics are totally different now, it feels like a completely different bike and will take a bit to get used to, but I can already tell they are super-glued to the road compared to my Continentals.
#22 ·
If you use wood or a boot in terms of getting the wheels back on. As far as tires go. Make sure they are room temp or warmer, the bead seats when its more plyable. I also use a head gun and windex on the beads.
Reactions: Brandon35
#20 · (Edited)
I’ll try and take some this week, I have pretty busy schedule. The plastics are completely shot, but the internals and mechanical pieces are almost all up to date now. Some time down the road she’ll be strictly track oriented and I can gut a lot of the crap and get new fairings but for now she’s happy.
Reactions: WildCard
#24 ·
I can't believe how drastically different the bike feels and how much more confident I am riding it. Having straight bars aid in the right/left pushing forces and the tires just make the bike want to carve the corner like a maniac. Will post pictures when I have spare time and good weather.
#31 ·
Took a few quick shots today. I know, the plastics (besides the hugger and fender) are total shit
#33 · (Edited)
Added safety wire to the rest of the bike. Did it all by hand with no real problem
Reactions: leising
#34 ·
Reactions: leising
#35 ·
Clutch went the other day. Just rebuilt it not long ago and was curious why i had felt such a subtle but noticable increase in clutch play. Opened it up and found the everything looked fine until I saw the end of the clutch comp release (the part that pulls the clutch out). Must have been worn down and weakened over time and finally chipped enough to simply jump over the rod instead of grab it. Drained the oil and refilled with fresh 10w-40 anyways. Only had 100 miles on the oil but the sea foam I used must have really cleaned her out because it was nice and dark.
#36 ·
#38 ·
Yeah I was really surprised at how clean the internals looked as well! Had two slightly more worn forks but other than that, honestly it looked pristine. I think my trans “issue” was a poorly torqued sprocket nut but im glad I got to do the teardown anyways!
Reactions: WildCard
#39 ·
Looks like I wont be keeping her long term like I had originally planned/wanted. Have to get a car and both the Zx and my Buell have been inconstant lately in terms of reliability. I have both listed up and hopefully they will go to good homes. Lots of blood and sweat into this old girl and it will hurt to see her leave, but she taught me a lot and I look forward to getting a newer ride. May not be another zx6r for a while, but I'll be around on the page. Will update if/when sold.
#41 ·
Riding is a state of mind, rather than a particular bike or time. Once it's bitten, the urge never really goes away. Dormant, possibly..... But unlikely to be extinguished.
Next time around, with more money and opportunity you will likely try something different. I'd suggest you to for as different as you can imagine... The range of rides is nearly infinite. Big touring rigs, to trials bikes, to pocket bikes, cruisers, choppers, dual sports, retro mods... Bounce around.
